The Maroon Menace. 455kw monsta! - Hardtuned.net - Page 3
The Maroon Menace. 455kw monsta! Silvia
DRE20 S14a KOUKI sr22det 310kw Precision 5858 Z32 Nismo
1387 replies to this topic
#61 DRE20
  • Car:97 s14a
Posted 25 September 2012 - 09:02 PM
nah, well.... it's seasonal. Every now and then it carrys on. I just dont boost it anymore. The car is pissin me off. Missing, howling on boost, f**ked cv joints. Cant win. lol. I need to build up some motivation to get stuck into it n properly sort it out, just cbf atm.. ECC are doin me up new ignition leads, so ill wait till they turn up and see if they make a difference, then if they dont ill change out all coilpacks, then if that doesnt fix it, ill have 4 spare coilpacks lol and i dunno what else ill check.
#62 DRE20
  • Car:97 s14a
Posted 03 October 2012 - 07:15 PM
so a little update
got under the car and had a bit of a look at my cv joint on the passenger side and discovered this (i knew it was damaged but didnt realise how badly exactly haha)
Attached Image: 149650_3989207734218_1283218237_n.jpgAttached Image: 302188_3989212894347_325227761_n.jpgAttached Image: 427847_3989204974149_1624263279_n.jpg
how it was after i took it out lol
Attached Image: 305945_4210133417222_660895731_n.jpg
these are on the way
Attached Image: 561491_10152117763900304_1861634635_n.jpg
r33 gtr cv joints with modified s14 half shafts
and also have r32 gtr rear hubs.
Hopefully that sorts out the problem of cvs that are wanting to fly apart all the time.
Edited by DRE20, 01 December 2012 - 10:22 AM.
#63 DRE20
  • Car:97 s14a
Posted 09 October 2012 - 05:23 PM
Attached Image: 541176_4009249075239_1296465631_n.jpg
new bits turned up... havent driven the car in over a week so im pretty keen to get these in ASAP.
#64 DRE20
  • Car:97 s14a
Posted 13 October 2012 - 10:53 AM
for the lulz
Attached Image: 183564_4029043010075_31707321_n.jpg
#65 DRE20
  • Car:97 s14a
Posted 03 November 2012 - 11:34 AM
Alright boys and ladies,
Bit of a big update.
Decided to change from standard s14 cv's over to R33 GTR cv's, not because i wanted to but basically i needed too due to the standard passenger side (the short cv) developing a pretty nasty tear and a bit of a rattle when WOT.
So here's the story.
I bought new modified half shafts
Attached Image: 578955_4096207969157_1522719193_n.jpg
turns out the passenger side half shaft was 11mm too long, so i needed to get it onto a lathe and trim the end of it off (the reason it was too long is because i have a nismo gt pro 1.5 way lsd which is actually out of an s15, also the thickness of these shafts is 31mm)
Attached Image: 530719_4112404574062_1740442155_n.jpg
Attached Image: 602405_4112420494460_1814400268_n.jpg
here we are putting a little taper on the end so it mates into the diff nicely
Attached Image: 530649_4112528817168_1022745994_n.jpg
Attached Image: 229889_4112430214703_1601557676_n.jpg
I put GTR hubs in it aswell so the GTR CV's would work with my setup, i didnt put the GTR Knuckles in even though i wanted too as they are made of alloy and nice and light because some of the bushes were f**ked and untill i can find new ones im not interested in them for now
so anyways, I got the cv and stub axle/half shaft put into the car, bolted the arms and shock back onto the hub, put the wheel on and done the nuts up, they drove the car down the street and first bump the car went over, the stub axle completely pops out of the diff.
GTR Driverside cv is overall 40mm shorter then stock s14 cv from driverside.
Attached Image: 254367_4112387493635_1276505884_n.jpgAttached Image: 487277_4112390493710_1236798153_n.jpg
So We decided to make a spacer to go between the stub axle and the cv
Attached Image: 644130_4113844810067_1206192949_n.jpg
and, while i was at it, tore that cv joint apart and changed grease in it and put it all back together good as new, also had the bearing casing of the cv bead blasted, good as new :)
Attached Image: 60689_4113290356206_1072310635_n.jpgAttached Image: 550103_4113292196252_2042699722_n.jpgAttached Image: 599233_4113294956321_1863397455_n.jpgAttached Image: 68061_4113838569911_2128119349_n.jpg
Next up was getting car on hoist and turning my diff torque setting to low as it was on high,
Attached Image: 21318_4112388453659_1927321224_n.jpg
then installing spacer and cv and stub axle and hub and bolting it all together and Road testing..
Attached Image: 405069_4113882050998_1227742531_n.jpgAttached Image: 545267_4113880530960_1421132201_n.jpg
Rear end should be sorted now, the car is a million times better to drive, it likes to turn corners now, the diff noises have literally gone thanks to turning that nut to the left to loosen it up, And all the low speed shuddering of the whole car have disappeared thanks to the GTR cv's. Money well spent.
Edited by DRE20, 03 November 2012 - 11:37 AM.
#66 quick_2L_turbo
  • Car:1994 S14
Posted 09 November 2012 - 11:54 PM
Really glad you got your shit together, because I got a good read out of it! Good to see you've had fun with it though looks like a sick set up all round dunno if you ended up getting coil overs but if you wanna make your car a bit more multi purpose I think it'll help (dunno if it helps for drags that much)
Definitely don't lose motivation man if I had my shit together I'd love to go thru what you're going thru, you've made this thing awesome since the start guess the hiccups are expected every now and then right?
Man I gotta hit up a diff lollol
#67 DRE20
  • Car:97 s14a
Posted 10 November 2012 - 11:26 AM
Yeah motivation for this car is a seasonal thing, sometimes ill leave it for weeks and just poke around to work and back then other times ill wanna fang it but knowing theres things wrong i get my motivation back to sort it out...
I was abit skeptical of the gtr cv changeover at first because they didnt fit like the dumbass who i bought all the gear from said they would, but me and some mates worked it out and got it done, I'm so glad we did, the difference is truely amazing, the diff is so much quieter, at really low revs and speed like under 40 the car doesnt jolt back and forwards anymore, it actually turns corners really well, it slides pretty good still too even though the torque setting is on low...
While we had the rear end apart we changed the rear main oil seal in the gearbox too because that was leaking and i put redline lightweight shockproof oil in the box and diff, the box is sooo much nicer now too, no more stiffness trying to get into gears, doesn slightly crunch quick changing from 3rd to 4th..
Next project is one of the new plazmaman intake plenums, There's a guy on here, SR20JOEL, Who's just had his all rebuilt and put one of these plenums on his and it make 20kw atw extra just by putting on the plenum so there's abit of inspiration for me to get that one, i was looking at them when they first came out thinking how f**king PORN they look also but didnt want to get one straight up as they hadnt done any testing on them, but seeing Joel's s13, im hell keen for one! I'll get a retune aswell and more boost and see how far i can push this setup before i max out injectors or fuel pump or it starts to knock... Will be interesting now that my motor is nicely run in.
Also have replaced my speedo sender unit on my gearbox so i now have a functioning speedometer. Winning! haha
As for coilovers, Ive got my eye on some silkroads, but im a little unsure about coilovers, theres so many different varied opinions on them, i want something that has height and damper adjustment, ill need camber adjustment for the front aswell but i want something thats good for drag racing as i dont really drift but at the same time it needs to be nice to drive on the street.. So thats basically where im at with that one..
And yes dude get a diff, they are so worth the money, Your traction levels raise HEAPS and they are pretty good for drifting obviously... Well and truel worth the money i reckon. :)
#68 DRE20
  • Car:97 s14a
Posted 16 November 2012 - 12:56 PM
Ok so today i decided to pull my dump pipe off to check it for cracks in the welds or something to try and figure out why the car makes such a stupid noise while its on boost (the almighty boost howl). Dont laugh at the dump pipe, i didnt do it! But i found a little nick in it so ill get that fixed. I wish *milkshakes* who worked on my car would stop being shitcunts.
pics for proof.
what a f**king shambles. See the black mark?
Attached Image: 63754_4172818164364_1135775414_n.jpg
a close up of the hole in the dump pipe
Attached Image: 259922_4172822084462_834991746_n.jpg
Edited by DRE20, 01 December 2012 - 10:30 AM.
#69 Protius
  • Car:S14 200SX
Posted 16 November 2012 - 01:42 PM
That tiny little hole won't be making such a loud noise. Exhaust leaks don't howl like that.
#70 DRE20
  • Car:97 s14a
Posted 16 November 2012 - 02:26 PM
well its not like anyone is helpin me and im not a mechanic so im just tryin to rule out everything bit by bit in what little spare time i get these days.
#71 robJDM
  • Car:S15
Posted 16 November 2012 - 03:15 PM
At least you found one potential issue mate :) Go over your intercooler piping and check the joiners for cracks. If your pedantic take it to a workshop and get them to do a smoke test. Otherwise there's a bike inner tube trick I've heard of but I can't remember how it's done.
Nice car and power by the way.
#72 DRE20
  • Car:97 s14a
Posted 16 November 2012 - 03:25 PM
thanks man. I've done heaps already to try figure out the noise.. I've got a whole other thread on it...
http://www.nissansil...l=&fromsearch=1
#73 DRE20
  • Car:97 s14a
Posted 24 November 2012 - 08:56 AM
Alright so for a while now since i went to the 1/8 mile drags a couple months ago the car has been missing and carrying on randomly, So a few weeks ago i bought 4 new bosch HEC715 Coilpacks and had them installed coz i could not of been f**ked doing it, and this week i contacted topgun ignition and measured up from my coils to my plugs and ordered new custom Leads... They turned up yesterday so i threw them on. They look heaps better. Should sort out the dodgy leads that were in it, hopefully no more missing.
PICS!!
Old shit leads
Attached Image: 294189_2066577389661_1401573302_32166590_6057070_n.jpg
new ones
Attached Image: 3685_4205195893787_1428930915_n.jpg
Attached Image: 63737_4205196453801_1379065419_n.jpg
my favourite shot
Attached Image: 188469_4205198853861_1818663660_n.jpg
hi res
Attached Image: Image511.jpg
Edited by DRE20, 24 November 2012 - 08:58 AM.
#74 aym23q
  • Car:S15
Posted 25 November 2012 - 01:50 AM
Hey yo Dre, how much ur leads cost if u don't mind me asking?
#75 DRE20
  • Car:97 s14a
Posted 25 November 2012 - 07:11 AM
with the seperators they were 172 bux.
#76 pauly180
  • Car:180sx, Gtir
Posted 25 November 2012 - 11:54 AM
nice build
Edited by pauly180, 03 December 2012 - 05:41 AM.
#77 SR20JOEL
  • Car:s13 silvia
Posted 01 December 2012 - 05:57 AM
f**k dude what happened to it?
#78 sssturbo
  • Car:S14 200sx
Posted 01 December 2012 - 07:11 AM
please tell me you didn't lift it out with plastic chain O.o
#79 sssturbo
  • Car:S14 200sx
Posted 01 December 2012 - 02:16 PM
ha ha pleased to hear, looks like you lifted it ok, sometimes i bolt on lifting eye's, diagonally at the end of the head, looks like that's where your is?
#80 greens14
Posted 01 December 2012 - 05:31 PM
That sucks man. What exactly happened? Just something gradual or you think it just went one day? I imagine it has copped a bit of a flogging since the build?
#81 Tom Tucker
  • Car:S15
Posted 01 December 2012 - 07:55 PM
Dude, it sounds like you've had a couple of engine problems now since the rebuild.... How many km would you say you've gotten out of the rebuild?
#82 DRE20
  • Car:97 s14a
Posted 01 December 2012 - 08:12 PM
probably like 9000.
#83 IHAVEARODEO
  • Car:Ra Rodeo
Posted 01 December 2012 - 08:21 PM
This car hates you. It hates itself. It's emo and keeps trying to kill itself.
#84 Tom Tucker
  • Car:S15
Posted 02 December 2012 - 09:34 AM
View PostDRE20, on 01 December 2012 - 08:12 PM, said:
probably like 9000.
Thats shithouse. I'd be pissed if I were you...
#85 DRE20
  • Car:97 s14a
Posted 04 December 2012 - 08:57 PM
wheels for sale if anyone wants...
http://www.ebay.com....46#ht_500wt_949
Edited by DRE20, 04 December 2012 - 10:56 PM.
#86 greens14
Posted 04 December 2012 - 09:15 PM
What are they?
#87 DRE20
  • Car:97 s14a
Posted 04 December 2012 - 10:49 PM
my volk gtc's man.. There should be a link under it?
#88 SRS13
Posted 05 December 2012 - 02:14 PM
Am I missing something? What happened? Did something happen to the engine? I cant see any posts like that!!!
#89 robJDM
  • Car:S15
Posted 05 December 2012 - 02:27 PM
I was just thinking the same?
#90 DRE20
  • Car:97 s14a
Posted 05 December 2012 - 03:17 PM
haha i decided to delete a couple posts from this page, however, there will be an extensive update in the very near future with a couple little suprises :) So stay tuned folks!
3 user(s) are reading this topic
2 members, 1 guests, 0 anonymous users
