HyperGear SR20det turbocharger Innovation, Evaluation and Testing - Hardtuned.net - Page 2
564 replies to this topic
#31 TurbostyleR
Posted 09 February 2014 - 12:43 PM
How do these turbos compare to the atr td06sl20g with the billet wheels that hg do. Looking at the website they hg show a sr20 setup that makes 200rwkw at 4000rpm and a Mac power figure of 270rwkw.
Do those billet td06s spool faster than the kando td06 20g?
#32 HyperGear
  • Car:180SX, S14, S15, R33, R33, 300ZX
Posted 09 February 2014 - 06:39 PM
Thanks for the inputs. the SL20.5 is an earlier version of a billet TD06 L2 turbine based turbocharger, it has out performed the standard 20G in both power and response based on a Rb25det.
The latest one is the SLSS2. under comparison it has same response as a standard TD0620G while made more power then a 25G.
Other thing worth mentioning is we have a different thrust setup compare to the Kando items. Which last much longer under high thrust load.
Edited by HyperGear, 09 February 2014 - 06:55 PM.
#33 TurbostyleR
Posted 09 February 2014 - 09:08 PM
do you still do the 20.5?
I'm chasing something that has the quick spool characteristics of the sl2 turbine or faster in an external gated t3 housing configuration for an sr20. Looking to make an easy 280-300rwkw on ethanol but don't want a lag pig.
#34 HyperGear
Posted 10 February 2014 - 08:05 AM
The 20.5 can still be made. some thing like what you need is best in a 8cm turbine. It did 280rwkws on a customer's SR20det E85 with pretty decent response.
#35 HyperGear
Posted 10 February 2014 - 08:15 AM
Also this is probably worth looking at which is the SLSS1 V ATR43SS2 V T67 in both power and response. The TD based are in 10cm turbine and the ATR43 is based in a .82 turbine. All based on a Rb25det motor externally gated
#36 Sandy Lewis 180sx
  • Car:1992 180sx SR20DET
Posted 10 February 2014 - 09:01 AM
Very interested in this development as i am looking for a nice 250Kw with good response as well. will be interesting to see how it come along. Any idea when they will be available for sale.
#37 HyperGear
Posted 11 February 2014 - 07:23 AM
Some thing like that would preferably be an ATR28SS15 or a G2. Once again it all comes down to the cams, it will be good if some one can post up an indication of percentage in gain or loses might be, on different sized cams. From there the estimation of output should be more precised. All the profiled evaluated are available, details are on our site.
Car's heading back to ForcedMotorWorx, its developed a loud rattling noise in the head. Hopefully just a problem with timing chain tensioner and looking to restore VCT on the same time.
Edited by HyperGear, 11 February 2014 - 07:25 AM.
#38 HyperGear
Posted 11 February 2014 - 09:01 PM
Add in one more results as few members requested. This is a back to back test on our SL20.5G V Ebay TD06SL20G
Run is on a RB25det, T3 10CM, high mounted externally gated on E85 fuel:
Edited by HyperGear, 11 February 2014 - 09:27 PM.
#39 Dose Pipe Sutututu
  • Car:Boat Sutututuutu
Posted 13 February 2014 - 09:38 AM
Hey Tao!
My SS2 external is nearly on the car haha, still being lazy 5th week on jack stands already.. only have made the dump, still need to mod the hotpipe & make a screamer pipe.
Anyhow, I've been messing around with my mate's S15 and he's chasing a figure of about 250kW however he wants everything to be bolt on, that means even the comp cover.
Are you able to machine the factory T28 compressor cover to fit the SS1.5 in the T2x rear housing? If so that would be fantastic.
#40 pur40m
  • Car:180sx
Posted 13 February 2014 - 11:12 AM
That's what I have ss1.5 in a s14/5 t28 comp housing and t2
Still yet to put it on the car and get tuned been lazy
#41 beersandwich
  • Car:513
Posted 13 February 2014 - 12:09 PM
DO IT!!!!!
#42 Dose Pipe Sutututu
Posted 13 February 2014 - 12:29 PM
what ECU do you have? I can tune it for you (provided your car isn't wildly modded)
#43 pur40m
  • Car:180sx
Posted 13 February 2014 - 01:03 PM
Just nistune
Nah not too many crazy mods just bolt ons
Poncams ras
Nismo 740cc injectors nismo reg dw300 rewired
Usual exhaust and fmic
Caltex eflex
Was just going to take it back to my usual tuner Unigroup for a touch up tune
As now I'm making 252rwkw with the atr28g2
I want atleast 270rwkw from it that's on eflex
You road tune but don't you ?
#44 Dose Pipe Sutututu
Posted 13 February 2014 - 01:23 PM
I do mainly road tuning, however I got a S15 going on the rollers this Saturday.
Do you have your own Nistune license & wideband?
#45 pur40m
  • Car:180sx
Posted 13 February 2014 - 01:29 PM
Nah man i leave the tuning to the professionals and do just the mechanical
#46 Dose Pipe Sutututu
Posted 13 February 2014 - 01:34 PM
That's fair enough, hopefully unigroup doesn't charge an arm and a leg to touch it up..
Essentially all they're doing is touching up the AFR when the turbo comes on song & adding 1/2 degrees more of timing up top (new turbo, less back pressure).
You should get a wideband and install it into your car, it's a great tool to have :)
My mate has a spare Nistune slot on the personal license, if you ever need a touch up on the road happy to help.
#47 pur40m
  • Car:180sx
Posted 13 February 2014 - 03:26 PM
You will be happy with your ss2 on your skyline
What fuel you using pump 98 or e85 ?
My bro just got his evo tuned with a slss2 chra in evo 9 turbo housings done by stao
Made 285.8 awkw on 25psi caltex e85
more boost would have cracked 300kw but it's still stock block
Both turbos use the same compressor but the evo slss2 is reversed and has a td06sl2 turbine
#48 Dose Pipe Sutututu
Posted 13 February 2014 - 03:33 PM
hell yeah, it's externally gated too :)
I will initially tune it on 98, get the optimal ignition timing across the map then will put it through E85 (I will just be lazy and blanket on timing across the entire map, then tune the high load areas on the dyno).
LOL I saw that post on SAU!
#49 sssturbo
  • Car:S14 200sx
Posted 13 February 2014 - 05:40 PM
just curious, how do you do timing when road tuning?
#50 The Big Fist
  • Car:s15
Posted 13 February 2014 - 06:38 PM
With a lot of risk !
#51 nicknack
Posted 14 February 2014 - 12:10 AM
No huge risk in it If you know what you're doing. You either use super good knock detection for 98 and let that tell you when you're reaching the limit (same as dyno really). On eflex/e85 (this won't work with 98) you log a WOT pull and import it into virtual dyno, it plots a power/torque curve, you bump up the timing, do another run, see the curve increase and you repeat until the curve doesn't increase with extra timing. At that point you've reached MBT, the minimum best timing figure which will give you max torque.
There's obviously much more to it then that, but as a rough idea of how you road tune, that's it.
#52 sssturbo
  • Car:S14 200sx
Posted 14 February 2014 - 05:57 AM
i know about knock detection, just didn't sound like knock ears or anything was used on the road, something i don't like the sound of
#53 Dose Pipe Sutututu
Posted 14 February 2014 - 07:43 AM
Spot on, however on the road I don't use aggressive timing because there's no real way to load hold and find knock.
I only tune lower powered cars on the road, once you start making over 250kW it's gets a little silly.
With newer ECUs such as adaptronic, you can just connect up headphones and listen for knock, however I've been told that nissan uses narrowband knock sensors, however works well enough for me :)
#54 The Big Fist
  • Car:s15
Posted 14 February 2014 - 09:36 AM
Agreed, I also tune my car with Nistune, albeit not that well !
The risk I was talking about is doing 3rd gear pulls on public roads. You really need a driver and a nice long flat country road.
#55 nicknack
Posted 14 February 2014 - 12:26 PM
Oh yeah, once you're making lots of power it gets silly. I get a mate To drive whilst I monitor and adjust. I haven't used the brakes to hold it at a specific load though. Just used WOT runs and logging to monitor changes
#56 pur40m
  • Car:180sx
Posted 22 February 2014 - 08:44 PM
Just finished fitting my ss1.5 to my 180sx previously had atr28g2
This turbo feels like it comes on to boost easier lighter throttle noticeable difference and on wastegate pressure 20psi seems to go as good as the atr28g2 on 25psi
Fullboost seems to come In at 3500-3700rpm very happy can't wait for tune in a few weeks
#57 mr_sleeper
  • Car:180sx
Posted 23 February 2014 - 06:29 AM
pur40m do you have standard or aftermarket cams or any other mods that help with response?
#58 pur40m
  • Car:180sx
Posted 23 February 2014 - 01:16 PM
Poncams aswell as the normal fmic and exhaust
Feels very similar to my old turbo setup with the hks2530 with a tomei expreme manifold but more top end power and comes on to boost instantly
Retune soon and 25psi
#59 pur40m
  • Car:180sx
Posted 26 February 2014 - 04:51 PM
Dyno didn't go the best today
On 20psi was making 250rwkw and power to limiter which was same power as before on 25psi but before power dropped off at 5600rpm now pulls to limiter
Yavuz said this turbo has more legs than the other turbo but as the boost was turned up detonation started to set in on 23psi was 263kw but slight pinging so left it at 20psi
I'm going to try the .86 rear on it in a few weeks and see how I go as he said the engine will be a lot happier with the .86rear on the higher boost pressure better
Hopefully doesn't hurt response too much but now it always starting to boost on any throttle
#60 ColS15
  • Car:S15
Posted 26 February 2014 - 07:16 PM
pur40m what was the peak torque, at what rpm. When does torque drop off?
Could you post the dyno chart?
What size injectors are you using, on pump 98?
