HyperGear SR20det turbocharger Innovation, Evaluation and Testing - Hardtuned.net - Page 19
565 replies to this topic
#541 pur40m
  • Car:180sx
Posted 28 January 2017 - 04:32 PM
Yes had a adjustable reg and extra bar fuel pressure
But make sure your fuel pump is up to the task
Need a walbro 460lph atleast rewired
I was on eflex which is usually about e70 so on united e85 will be alil less headroom
#542 HyperGear
  • Car:180SX, S14, S15, R33, R33, 300ZX
Posted 03 March 2017 - 10:55 PM
Ball bearing option is now available to all ATR28 series and TD06-SL205 series.
We can carry now carry out bush bearing to ball bearing conversions to all Garrett T25 / T28 based bush bearing turbochargers, as well as other TD06 and TD05 based turbochargers.
#543 mr_sleeper
  • Car:180sx
Posted 04 March 2017 - 08:20 AM
how much extra to go ball bearing in an atr28ss1.5?
what would be the difference in the way the turbo behaves between bush and ball bearing in the atr28ss1.5?
#544 HyperGear
Posted 04 March 2017 - 09:32 PM
You will be looking at $450 to carry it out. There is a pretty noticeable difference in throttle response.
#545 RyanSD180SX
  • Car:94 180SX Type X
Posted 06 March 2017 - 03:56 PM
Does the ball bearing conversion make it spool up much quicker?
For example will an ATR28SS2 ball bearing come on as quick an ATR28SS1.5 bush bearing?
From memory I think there's a 300rpm difference between the two reaching full boost (20psi) in a bush bearing setup.
#546 mr_sleeper
  • Car:180sx
Posted 16 March 2017 - 07:08 AM
I am curious on the answer to this too as I was looking at the atr28ss1.5 for the response and the answer might make me change my mind
#547 Varvs
  • Car:97 180sx Type X
Posted 16 March 2017 - 08:53 AM
Ball bearings are maybe 500rpm faster at the most.
#548 Goliath101
  • Car:99 S14a
Posted 16 March 2017 - 05:22 PM
Thought I read somewhere that there wasn't a massive differences in the ATR28 series?
#549 pur40m
  • Car:180sx
Posted 16 March 2017 - 06:24 PM
Its not just full boost will come on sooner
Transient response will be much better with ball bearing
#550 HyperGear
Posted 20 March 2017 - 03:46 PM
It really comes down to the size of the wheels and housing. Ie, if I run an ATR28SS15 on BB I probably won't notice much differences, while SS2 will be quite noticeable.
#551 Wizard
  • Car:Moneypit
Posted 22 March 2017 - 07:10 PM
Transient response is life changing with ball bearing in general. At 4000 rpm, my HKS 2530 would hit boost quicker than a bush bearing T28. I thought when I downgraded the T28 would be on boost all the time, but the car was a dog in between bursts. I dont care when full boost is so much, you can drive around it, but losing transient response killed the car.
#552 andhey
Posted 25 March 2017 - 01:58 PM
Going to get my ss2 bb'd and also going external gate at the same time along with a touch up tune. Will be interesting to see the difference
#553 RyanSD180SX
Posted 27 March 2017 - 03:32 PM
I'd like to see some dyno results of the ATR28SS2BB to get an idea of the response.
My ATR28SS15 comes on full boost (20psi) at 3.7krpm and I feel like much laggier than that wouldn't feel the best on the street.
#554 HyperGear
Posted 13 April 2017 - 09:04 PM
Video footage from Victoria Time Attack last week at Philip Island. Our team won first at 1.35.72
TopStage S14 SR20det running our ATR45SAT BB turbo made 399rwkws@ 28psi
#555 liambrm
  • Car:1993 180sx
Posted 14 April 2017 - 09:07 AM
absolute beast love to see dyno sheet looks responive.
#556 HyperGear
Posted 02 June 2017 - 10:07 PM
Some results to update:
This is an S15 with Drop in cams on E85 fuel. Car made 420HP using our ATR28SS15 turbocharger from Mid 2014. This should be one of the earlier SS15 versions, the later model held more boost. But either way it managed to pull pretty much identical figures are mine converting to P98 result.
Also adding customers feed back in the past few years. Apart from big cooler, free flow exhaust induction pipe plus step two cams as we already know. It also appear the car that made close power figures as my own has an aftermarket exhaust manifold.
I believe Liam (the guy made 297rwkws out of the ATR28SS2 P98 fuel internally gated three years ago) did a stock manifold swap due to cracks, ended up losing 30kws. He's putting another low mount back on and we should be able to confirm the case for sure.
#557 liambrm
  • Car:1993 180sx
Posted 05 June 2017 - 03:21 PM
297 rwkw on internal gate yes will be higher than that soon
#558 RyanSD180SX
Posted 07 June 2017 - 03:31 PM
Do you have any recommendations on manifolds?
Is any tubular manifold ok or is shelling out for a tomei expreme worth it?
#559 Goliath101
  • Car:99 S14a
Posted 07 June 2017 - 04:59 PM
I don't believe there is much benefit over the stock manifold if saying low mount
#560 liambrm
  • Car:1993 180sx
Posted 08 June 2017 - 06:54 AM
My 265 was with a leaky waste gate.
Made good power on stock mani once gate was sorted but couldn't rev out got stuck at 285 at 7000
Made 307 on 26psi at 6200 but it chocked up from there so going back to tubular
These results all have a wastegate on the turbine housing
#561 liambrm
  • Car:1993 180sx
Posted 09 June 2017 - 05:21 AM
Also my last results where on a 38degree dyno cell day made 298 on a 29 degree dyno cell last time
#562 yld:18e
  • Car:nissan 180sx
Posted 04 July 2017 - 04:10 PM
Is there much difference in response between the stock and tubular manifold?
#563 pur40m
  • Car:180sx
Posted 04 July 2017 - 09:27 PM
Depends on the design of the manifold
#564 RyanSD180SX
Posted 26 July 2017 - 02:11 PM
Im looking into whether or not it's worth buying an aftermarket exhaust manifold and I came across this test. I wonder what you guys think of it.
https://www.full-rac...est_writeup.pdf
#565 HyperGear
Posted 04 August 2017 - 03:17 PM
Some video footage from Last weeks Victoria Time attack at Philip Island GrandPix.
ATR45SAT Turbocharger Powered Top Stage S14 SR20det (400rwkws @28psi, E85 fuel). Taking first in Modified class. Driven by John Richardson
#566 liambrm
  • Car:1993 180sx
Posted 06 September 2017 - 03:54 PM
not that this will be read as its impossible to find but i got my setup to go easy 307rwkw on pump fuel with a hypergear turbo at 24psi just used a good stainless mani and gate on turbine housing now time to go e85
  • Google
