R34 GTT brake/Hub upgrade on a 180sx - Hardtuned.net - Page 2
42 replies to this topic
#31 davidg2152
  • Car:S13 SR20DET
Posted 10 May 2016 - 09:13 PM
Ok mate sweet.
What bm50 do I aim for?
What model?
#32 robbo_rb180
  • Car:sil80 & s14
Posted 11 May 2016 - 08:40 AM
z32 or r32. Which ever has the same port locations as s13.
#33 davidg2152
  • Car:S13 SR20DET
Posted 12 May 2016 - 06:26 AM
Have bid on a R32 GTR M/Cyl so see how that goes. I have grabbed some GKTech brake lines and may get the abs delete as well so I can run the BM50 ABS M/cyl if I end up going that way.
#34 B00sted180
  • Car:180SX
Posted 12 May 2016 - 07:34 AM
I have a HFM BM57 in my 180 with R33 GTST brakes all round and it feels great in my case. I have heard a lot of people do have problems with them though. I originally tried using a R33 BM44 which should have matched the brakes but was way too soft.
#35 davidg2152
  • Car:S13 SR20DET
Posted 12 May 2016 - 07:41 AM
Awesome mate thanks for the feedback.
If this bm50 falls through (will be 3rd one sale falls through of it does) I think I will just try one of those.
#36 davidg2152
  • Car:S13 SR20DET
Posted 17 February 2017 - 07:36 AM
Bit of an old post. I currently have R34GTT front with W5 Winmax and R33 GTST rear with Winmax W3. I am running a GTR abs master cyl (BM50) with GKtech lines splitting the front port left and right.
On hard braking I am getting some lock up in the front on the track. I can avoid this buy braking earlier but would like to try and get the modulation a bit better. I will muck about with tyre pressures this weekend but just after any ideas as to what could work better.
I am using Castrol race brake fluid.
Dave
Bit of an old post. I currently have R34GTT front with W5 Winmax and R33 GTST rear with Winmax W3. I am running a R32 GTR abs master cyl (BM50) with GKtech lines splitting the front port left and right.
Dave
#37 Wizard
  • Car:Moneypit
Posted 17 February 2017 - 08:09 AM
GTR brake master has huge front bias.
Master's have two features - the inherent bias, and the 'knee point', which is when bias comes into play. It is referred to with a torque figured. Most nissans are proportioned something like 0.6 front and 0.4 rear brakes, with ...40? kg.m knee point. GTR's have a 20 kg.m knee point, meaning any more than a toe on the pedal will favour the front brakes.
I was going to run a Z32 BM57 on my car, but the brake shop I got to service it destroyed it pulling it apart.
#38 Varvs
  • Car:97 180sx Type X
Posted 17 February 2017 - 08:12 AM
I have an R34 GTT BMC and its pretty balanced. feels identical to the S15 BMC i had on previously.
#39 davidg2152
  • Car:S13 SR20DET
Posted 18 February 2017 - 06:12 AM
hmmmm.
I must have got a dud steer somewhere as everyone I spoke to said the non abs or line split abs gtr bmc was way to go.
perhaps I should change it out to the r34gtt unit???
not that hard a job anyways.
#40 davidg2152
  • Car:S13 SR20DET
Posted 18 February 2017 - 06:31 AM
so maybe try a r34gtt master u think?
#41 Wizard
  • Car:Moneypit
Posted 18 February 2017 - 08:10 AM
Anything that isn't GTR would probably be better.
#42 davidg2152
  • Car:S13 SR20DET
Posted 18 February 2017 - 12:03 PM
ok mate thx.
I'll test it at wakefield and play with tyre pressures
if no luck ill add a r34gtt master and see if it's better.
Thanks
#43 davidg2152
  • Car:S13 SR20DET
Posted 20 February 2017 - 02:46 AM
well I dropped pressure to 26 psi and prob solved. What a difference 2 psi made. Not one single lock up all weekend!!
