Big hp rb25 setup. Bolt in for s chassis. - Hardtuned.net
4 replies to this topic
#1 robbo_rb180
  • Car:sil80 & s14
Posted 19 January 2017 - 10:59 AM
Selling the complete engine setup from my car. Very reliable and well sorted setup
308kw on 98, 370kw on e85
complete flex fuel setup
Will not separate parts
Will freight at buyers expense
Built rb25 by red r racing:
Mahle pistons, spool rods, balanced and grub screwed crank, crank collar, partly grout filled, arp bolts and studs, nitto oil pump, tomei poncams, head has a bit of work, oil restrictors and head drain, enlarged sump with tomei gtr copy baffles.
Rb26 engine covers with mines baffles
Ecu and ignition:
Link g4 ecu
Splitfire coils series 2
Ethanol, inlet air temp, oil and fuel pressure sensors
complete engine loom requires 4 pin deutsch plug to connect to body- POS, Fuel pump, IGN and start signal
Turbo and inlet:
Gt3076r- ceramic coated
6boost manifold- ceramic coated
Turbosmart 60mm external gate
3 inch stainless v band dump pipe- heat wraped , port for wide band sensor
Greddy plenum- ceramic coated
Q45 throttle body
Fuel:
Xspurt 1000cc injectors
Gtr fuel rail- ceramic coated
Nismo fuel reg
Comes with all braided Teflon lines, radiator, headertank and Setrab oil cooler.
Can come with engine cross member
No clutch or gearbox
$15000 or
$14000 with std rb25 engine covers and std fuel reg
Pm for more information
edit: pics and more info added
  • Attached Image: DSC_0437.JPG
  • Attached Image: DSC_0436.JPG
  • Attached Image: DSC_0435.JPG
Edited by robbo_rb180, 19 January 2017 - 07:04 PM.
#2 robbo_rb180
  • Car:sil80 & s14
Posted 26 January 2017 - 02:58 PM
Bump
#3 Scotties15
  • Car:S15 200sx
Posted 28 January 2017 - 07:25 PM
Good luck with the sale.
Whats replacing it mate?
#4 robbo_rb180
  • Car:sil80 & s14
Posted 28 January 2017 - 08:21 PM
Thanks Scotty, nothing for a while have to down size the fleet first but looking at a Ferrari or maybe a porsche.
#5 robbo_rb180
  • Car:sil80 & s14
Posted 07 February 2017 - 01:27 PM
Bump
