Sil80 track car shell - Hardtuned.net
Sil80 track car shell Australia - QLD
6 replies to this topic
#1 Simonster
  • Car:Sil80 GTR Legnum
Posted 05 July 2017 - 08:48 PM
Price drop $3000
Offering for sale my track car. Yes i haven't been active on here in a long time, the last 4 years I've been looking after my son. Came to the conclusion i'll never get back to the car, so here it is.
Its track only, extensive cage that also goes through the firewall and ties the front strut towers together. Cage was built with FIA in mind however the "Larry bar" will prevent that. If its an issue just cut it out.
Sound deadening removed
Comes with Titlton pedal box with brake bias adjuster.
HKS Hypermax2 7kg front 5kg rear. Old now but were effective.
ARE dual pass radiator. This item is just brilliant. Kept the RB25 at 90 degrees on the track, and then soon as you're out of it, it would come back to the thermostat opening temp.
Has headlights and blinkers, just not in the pics.
Paint has nicks and some starches after sitting in a worksop for many years. It has a steering column but it's not currently fitted.
The rear 1/4 windows are included but not fitted, it was getting lexan windows.
Has a standard LSD 4.1 ratio. Still quite tight.
Current cross member was modified for a VQ so fit the cross member to suit your engine.
Will come with some 32 GTS-t rolling wheels.
Happy to answer questions Cage cost me $6000 alone, so i think $4000 for the entire shell is pretty decent.
I've also got some brand new carbon fibre doors i imported from the US that I'll list on here and a KAAZ 1.5 way diff which is still in the box unused.
Thanks
  • Attached Image: IMG_20170625_113819.jpg
  • Attached Image: IMG_20170625_113847.jpeg
  • Attached Image: IMG_20170625_113856.jpg
  • Attached Image: IMG_20170625_113906.jpg
  • Attached Image: IMG_20170625_114002.jpg
  • Attached Image: IMG_20170625_114113.jpg
  • Attached Image: IMG_20170625_114213.jpg
  • Attached Image: IMG_20170625_114233.jpg
  • Attached Image: IMG_20170625_120828.jpg
  • Attached Image: IMG_20170625_122256.jpg
  • Attached Image: IMG_20170625_122853.jpg
  • Attached Image: IMG_20170625_125007.jpg
Edited by Simonster, 14 July 2017 - 04:12 PM.
#2 sc s15
  • Car:s13
Posted 06 July 2017 - 06:53 PM
Bugger. Was hoping you would get this finished one day.
#3 Simonster
Posted 06 July 2017 - 09:36 PM
Hey, it did get close, twin turbo VQ built & installed with gearbox etc All with iqDash truck loads of sensors for logging etc etc but those bits are gone, the shell and a few other bits n pieces all that remains...
#4 robbo_rb180
  • Car:sil80 & s14
Posted 09 July 2017 - 07:26 PM
just a question about the radiator. Would an a/c condenser still bolt in to factory holes?
#5 Simonster
Posted 11 July 2017 - 10:11 PM
Yes
#6 Simonster
Posted 11 July 2017 - 11:19 PM
Yes
#7 Simonster
Posted 14 September 2017 - 12:26 PM
Sold
Sold
