180athid
Quality 180sx PART OUT do not miss out
hey guys
Stripping my 7 year build total package as been driven for a total of 50 km
car is located in Melbourne Don't ask for individual items
prices are set as packages !
I don't want to swap for anything
I would like to sell the engine package or rolling shell first don't mind keeping the drivetrain or whatever for a future project.
send me a Facebook msg or to my phone number 0402670354 if you want further info.
keep in mind this ad will be listed on a few groups and sites
Nissan 180sx 97 type x
Engine package $12,500
Nissan Sr20det (s14)
Full rebuild
Tomei 270 mm 12 mm lift cams
Tomei solid lifters
Tomei springs
Tomei rocker arm stoppers
Ported intake and exhaust ports
Je pistons
Manly rods
ATI harmonic balancer
Greddy larger engine sump
Greddy alloy engine pulley
Nismo bearings
Nismo 1.4 mm head gasket
Nissan gasket kit
Nissan oil pump
Nissan timing chain
Arp head studs
All machining and balancing done
Chase bays power steering reservoir
Power steering pump relocation kit
Cusco engine mounts
Gktek engine fan
Motul 6100 15w50
Ikeya formula quad throttle intake plenum
Ikeya formula fuel rail
Turbosmart FPR 1200
Bosch 2000cc injectors
Speed flow fuel lines
Nismo gtr fuel pump
Apexi Rx6 turbo kit
Apexi stainless manifold
Turbosmart 45 mm waste gate 14psi spring
custom down pipe to cat
Speed flow fittings to boost controller
Titanium 3.5 inch intake
Bmc air filter 4 inch
Trust intercooler LS
Custom alloy piping
Blitz Zs radiator
Blitz radiator cap
Samco radiator hose
Nismo thermo stat
Hks oil cooler kit custom
Chasebays millspec engine harness
Rachem + hide away
Apexi power fc
340rwkw 22psi e85
Drivetrain $10,000 if bought all together
HKS 6 speed H pattern dog engagement gear box (holinger) $8500
gearbox suits s13\s14\s15 sr20
Motul Gear comp 75w140
Ogura twin plate clutch
Custom single piece drive shaft that meets with any r200 diff
R32 Gts4 rear diff $2000
R32 Gts4 32 mm drive shafts
Nismo GT PRO 1.5 way
Trust Differential extended sump
Wheels/Tires $2800
RAYS Volk Racing Te37 super laps 50 km use
17 x 9 +22
18 x 9.5 +22
will come with tyres Bridgestone
Exterior Roling shell $13,000
Was registered until last year
Front tubs
Full respray in and out
White with house of kolour white ice
Hot Road genuine body kit
Front bar
Side skirts
Rear valance
Ganador mirrors
Genuine type x tail lights
Genuine type x rear spoiler
Rps13 centre garnish
Rolled and pulled front guards
Rolled and pulled rear guards
GP sports DG5 coilovers
Swift 10k 8 k springs
Drift works front drop down drift knuckles
Nismo front power Brace
S15 front control arms new ball joint + Nismo inner bush
Steering rack moved 15 mm forward
Tien tie rods and ends
Hard race front swaybar
S14 rear subframe +solid offset mounts
S14 rear lower control arms + nismo inner bushes
Drift works drop down rear knuckles Power by max (Pbm)
Pmb front castor rods
Pbm rear traction rods
Pbm rear camber arms
Pbm rear toe rods
Hard race rear sway bar
R33 gts front brakes
R33 gts rear brakes
R33 gts rear drum hand brake
Braided front and rear brake lines
Slotted disc front
Slotted disc rear
QFM Hi temp pads
Stripped interior
4 point half cage weld in
Blitz white uras edition id3 boost controller
Deleted heater and aircon
Interior wiring tuck brand new wire and fuse box + micro relays
Billet battery tray + odessey d51 battery
Nardi 350 mm deep corn steering wheel
Drift button
Defi control unit currently not working need new link wire
Defi oil pressure
Defi water temp
Defi oil temp
Bride Vios Low max driver seat $2500
Bride Vios Low max passenger seat
Bride Low max seat rails x 2
12637322_10153342933825778_1992672052_o.jpg10987653_595101370592849_7588074273776334487_o.jpg11221491_410860795766238_8538647783488197562_o.jpg11270486_1090953467588489_3929396088552988512_o.jpg11334009_595101233926196_645061552437227028_o.jpg
Edited by 180athid
This is on carsales as a complete car hey? Are you giving up on selling it as a whole and wanting to sell it in bits instead?
Pretty sure he summed it up with the fact hes only selling it in packages.
