drez
buzzing and rattle noise on 4000rpm
hey all,
I had this buzzing or small rattle noise when im on 4000rpm, regardless what gear I am in.
I've checked all my under body heat shield, front pipe/dump pipe connection, all exhaust line nothing is loose.
I've make sure everthing secured
The noise coming out of gear knob/gearbox somewhere, you can actually feel it rattle/buzzing thru your hand when you are about to gear change
Anyone has this problem can shed a light for me
oh the car is JDM s15 ;)
check the little slider on the gearboot that slides in under the gearstick is sitting under the gearstick properly.
mine vibrates and buzzes at a certrain amount of revs and i just play around with it till it stops buzzing.
can feel it through my hand tooo
hmm...i havent open that part yet
good idea, i'll try that tonite
do you have a short shifter? some cheap ones rattle like a biatch :ph34r:
still no luck, i opened the gear knob panel cant find anything there that caused the buzzing/vibrates noise at 4000rpm
anyone has idea?
hopefulyl it doesnt come from inside of my gearbox
