Hobbsie
What oil should I use?
Just bought an 03 350z, going to change engine/gearbox/diff oil.. Anyone have any recommendations for what oil to use?
Edited by Hobbsie
redline MT90 for box and diff, as for motor just use factory reccommended weight, I like motul 8100
For someone that has been here as long as I have, you really haven't figured out how to research, have you
OEM Nissan
Yeah a couple of people have recommended OEM nissan oil for the engine.. I'll give it a crack, never used it before haha
Well I couldn't find any threads specifically on 350z oil, so I thought I'd contribute to the 350tuned mechanical section by starting one ;)
Edited by Hobbsie
How many km's on the car?
For engine oil I use castrol edge 0w-40 as my 350z only has 30,000 kms.
If you have more k's I would consider a slightly thicker oil. I'm using castrol as the car had a castrol service sticker on it from the Nissan dealership when I bought it, so I figured may as well keep the same brand
Edited by darkone
80,000 kms.
The guys on the z forum in the states all seem to use 5w-30.
Australia has a different climate to USA. I dunno if I would use 5w-30.
5w-30 is recommended for outside temperatures of -30 degrees celcius to 15 degrees. I think you want that second number to be a bit higher for our warmer climate? My understanding is the higher that second number, the thicker the oil will stay at high temperatures. Thicker oil at high temperatures I believe to be more suitable for hot climates.
If anything, 10w-40 probably seems like a pretty well suited grade for Australia.
For manual gearbox oil I think it's 75w-90 with an API GL 4 fluid.
Diff oil needs to be API GL 5 and 80w-90.
Brake fluid I would be using a DOT 4 (don't mix the different grade types though!)
Coolant is pretty subjective. I just use tectaloy 90+.
Power steering fluid, just regular power steering fluid I suppose? Dextron 3 type.
Yep, I use the same here.
Relevant:
Edited by schift
I have a question about diff oil.. the recommended viscosity for the 350 is 80W-90, but all the LSD diff oil I see is around 80w-140? Do I need specific LSD oil or is any 80w90 API GL-5 oil ok?
